brokenrinker
- Jul 16, 2012
- 1
'95 Alpha Gen II - found oil leaking out of end cap of starboard trim cylinder. I've learned that you can get either a "cylinder rebuild kit" or an O-ring (seal) kit. The first goes for anywhere from $100 to over $200 the O-ring kit can be had for around $20. The tilt/trim works fine except for the leak. Which kit am I likely to need?
Thanks
Thanks
