ffengine28
- Jan 21, 2013
- 9
I just re installed my lower unit as I have done many times and this time something was kinda tight going on. The lower unit did not slip on as easy so i used a wrench to bring it all the way up on. I immediatley noticed motor oil leaking from the water seal around the shift shaft at the top of the pivot arm. I removed the lower unit and the oil leak stopped. Any help on what I could have damaged? Apparently I bound something up.
