Hi, I have a small leak from my around front crankshaft pulley. I have the manual and it explains how to remove and install. It doesn't mention anything around any seal or lip seal between the timing cover and the pulley or hub.? Is there a seal and is it accessible with out removing timing cover? The special tool required to remove polygon hub is that a must? Would this leak have any thing to do with vibration issue when turning the 280 leg or would this be a different thread again and another drama?
