Hi,
I've spent the evening pouring over discussions regarding the use of Closed End Blind Rivets for replacing loose rivets. Those that recommend them say to get the steel mandrel type. If you had to remove that rivet in the future, drilling the rivet out would likely result in an elongated hole because the drill is going to walk to the outside of that mandrel, would it not? Thoughts? Boat has a floor, therefore I'm very motivated to use something like the closed end rivet.
