I'll try to summarize so that as many people read this as possible.
1974 Evinrude 135 HP, Problem-- fouling spark plugs.
We have tried different oils, different ratio's, different spark plugs, rebuild carbs, adjusted floats, checked compression, link & sync, 4 new coils all to no avail. We troll a lot but I still think it is unacceptable to have to buy 4 new plugs every time we go out. CDI trouble shooting guide has been close companion. My stator is oozing goo, but still gives me voltages withing the acceptable range. I already tried a new powerpack, but my spark still seems weak (as seen jumping a 7/16" gap) and is intermittent. (trigger coils are also doing their jobs.) My theory is that even though I have correct voltages going to my power pack my current (amps) might be low which is causing a weak spark and incomplete combustion.
Has anyone ever had such an issue? Now I did break down and buy a new/used stator, but wanted someone to attest to my theory before I started the swap..
I have been told that if the spark jumps the gap that it is strong enough, but I'm not convinced. I want to see a bright fat blue spark and all I'm getting is a skinny faint yellow arc.
Tell me your thoughts, Thanks
