  #1
Old March 7th, 2005, 03:34 AM
Wizard1 Wizard1 is offline
Default replacing floor of fishing boat
Hey Guys, I did a search but could not find anything so here is my question. I have a 15' semi-v bottom boat (alum) that has a plywood floor. I am about to replace it and someone suggested that I use aluminum plate instead of wood. Has anyone here ever done this and if so how do you like it? My boat has about wood from the back bench seat by the motor to just short of the bow seat that comes to a point. Also if someone has done this how would you suggest doing it to make it look good and be functional?
  #2
Old March 7th, 2005, 04:38 AM
MichaelMullis MichaelMullis is offline
Default Re: replacing floor of fishing boat
I know 2 people that have done that to their boats, but they own a fabrication shop. Get a price on the metal and labor, I beleive the weight that you save on the boat will be less than the weight that you lose from your wallet.You can replace several floors for the cost of material.
  #3
Old March 7th, 2005, 06:28 AM
jimmythekid jimmythekid is offline
aluminum is WAY expensive, and has to be mechanically fastened, either by welding, or riviting, the latter most likely Buck Rivits, which require two people to rivit and special tools rivit them in, as well as access to the rear (underside) You cant just screw it down like wood, the dissimailer metals (steel screws/aluminum plate)will corrode quite quickly i would think. Resin coated wood, will last a long time, provided its not allowed to stay wet all the time. If you have a TIG welder, and/or a couple buddies to help out, id say go for it. But a piece of aluminum that size isn't going to be cheap. Id use wood again if it were me. how about some pics?
  #4
Old March 7th, 2005, 08:01 AM
Moody Blue Moody Blue is offline
As already pointed out, aluminum is expensive and will cost 5-6x as much as a wood floor. Two other points to consider are heat and reflection. Aluminum loves to absorb heat and will get very hot in direct sunlight. What about the sun reflecting off the aluminum. You'll either need welders goggles or cover the floor with carpet. Paint on an aluminum surface won't standup very well to foot traffic. I'm not certain of any weight savings. 1/4" aluminum weighs 3.54 Ib/sq ft. and 3/4" plywood weighs 2.35 Ib/sq ft. Im for the wood approach. Easier to work with, cheaper, lighter and I think quieter as well.
  #5
Old March 16th, 2005, 06:55 PM
luisjg luisjg is offline
you can also use starboard ,,nice!!
  #6
Old March 18th, 2005, 05:28 AM
Luisjg, what is starboard ?
  #7
Old March 25th, 2005, 11:55 AM
Thanks guys, I think that I hae settled on going with wood due to the cost and the other points made in this thread. Once again, thanks guys.
  #8
Old March 31st, 2005, 05:04 AM
Well, I thought of another question that I think I know but need confermation before I screw up. The last floor that was in my boat did not have anything underneath it to help support it and therefore the floor started to sag due to the pedestal seats I mounted in there. How would be the best way to support the floor? Would adding stringers along the length of the boat (down the center) be the best way or place one on either side of the center?Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
when replacing floor, how important is it realy to leave the lip of old floor bigbad4cyl Boat Restoration and Building 6 July 3rd, 2008 05:40 PM
Replacing Floor in boat katiedoes Boat Topics and Questions (not engine topics) 7 January 18th, 2006 05:18 PM
replacing floor in alum Sylvan boat mollycat Boat Restoration and Building 9 September 30th, 2003 10:51 PM
Replacing floor wellcraft cat Boat Restoration and Building 2 September 26th, 2003 08:26 PM
Replacing the floor on a RIB Magnet6x6 Boat Restoration and Building 0 April 30th, 2003 06:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
