Finally took this 120 out to the water and did some more testing and could really use some advise on what to check next.
After I cleaned some bad connections it seemed to idle and start much better on muffs but was not the case when it was in the water. It was hard to start and would barely stay running again now that it was submerged.
I did a couple tests that I found on this forum and now need to figure out possibly causes based on my findings.
Carb Check with cleaner:
Sprayed the cleaner in each cylinder and three of them would cause the motor to choke out when sprayed but one carb would REV the motor and make it sound better (well to my newbie ears).
Coil Check:
Pulled the plug wires one at a time and three of them would cause motor to run even poorer when pulled but one would not change a thing. Went ahead and swapped coils but had no change. Held plug wire and saw blue spark jumping to plug so "think" I can eliminate coil issues now.
ALSO..Spitting Fuel:
When I first took the carb cover off there was a bunch of fuel / oil in there and when this thing is running there is fuel spitting out of the carbs. Being a newbie still I am unsure if some fuel spitting is normal or not but this seemed excessive and it looked like it was coming from some gold colored screws (just read these are the idle air bleed orifice and the intermediate orifices).
update: previous owner had been trying to fix the rough running issue and had carbs professionally rebuilt, new VRO, fuel system cleaned out etc. but did NOT clean the totally corroded grounds all over the place (including seriously bad coil grounds).
possible theory from this newbie...grounds were causing original problems, he had all the above work done but didn't get it fixed..motor sat until he sold it and one of the carbs got gummed up. AND / OR this thing has a failing power pack or more bad wires somewhere.
Oh and the throttle advance was gummed up and not advancing when I got it..can't get the flywheel off to look under it though.
All help is greatly appreciated...thank you.
p.s. I can add photos and or video if that helps.
Coil Check:
