Hello everyone, I've read the previous posts regarding this motor, and I can't find what I'm looking for regarding this issue. Last season I changed the lower unit oil (type C) as usual, before launching my boat. The motor started & shifted into reverse with no problem at idle. However, when I raised the rpm even a little, it slipped out of gear. I nursed it while out for the day, by only using reverse in idle to accomplish whatever manuevers were needed. When I got the boat back home, I drained the LU oil again & refilled with new Type C ... from the bottom drain plug until it flowed from the upper vent plug. The next time I launched I had the same problem in reverse when the rpm was raised slightly. Forward & nuetral work fine, and shifting into reverse works fine. It is only slipping out of reverse. There are no signs of debris or metal in the drained fluid, and no signs of water/oil. Could this be a weak solinoid, or a damaged reverse gear, or.....? I'm set on keeping this motor, regardless of "some" of the negative feedback. However, I hope that doesn't turn off anyone's suggestions & help. Thanks in advance
