Re: swap 140 for a 120
as long as the 3.0 is pre1990, it's a direct swap. post-1990 would require you get the coupler/flywheel with the motor
Pull the engine first, if it's coming out anyway, that'll get you right in close to the gimbal/shaft so you can soak it with penetrant.
