1985 Yamaha outboard 70 HP. Bought motor used, had sat for 12 years, rebuilt carbs, replaced water pump kit.
Installed on new boat and test ran.
Do not have a green light on the engine gauge at any time.
have a red light and buzzer when running. Oil tank is half full. Engine heads are cool to touch. Runs like a scalded skunk, no limiting of RPM.
I believe it is a false alarm, but would like to prove it.
Troubleshooting the gauge shows only red light lights correctly, red light lights when green light should and yellow light does not light at all.
Apparently gauge is bad.
Can't find a source for the 3 light yamaha gauge, red light, yellow light and green light.
Why isn't it limiting RPM if it thinks there is a problem?
I believe the oil sensor only is for oil level on this engine? No way it could be sensing oil pump issues or old oil sludging in bottom of oil tank or in pump/lines? Marked level on oil tank and it appears to be using oil as I have test ran it.
Any way to disable oil level sensor or fasten it in up position?
Thanks for the help.
It is a beast of a little motor!
