I recently bought a used gear box, replaced the impeller, and installed it. It seems to be ok, but i have no reverse. When i installed it i put the shifter in neutral and the box in neutral because i couldn't get the shifter splines lined up any other way. In forward it works great, neutral is free spinning, and in reverse the prop will turn about one third turn each way with motor off, as it should i think. But in the water the prop seems to spin while in reverse but there is no thrust. Any ideas? Forward and neutral work fine in the water.
