vince72801
- Jan 7, 2013
- 39
Hello,
I'm still working on this 4.3 ser# 0m099909 with TKS. Background, I bought this boat at a "as is where is" price with the with owner saying its starts but need carb work. I replace the plugs, wires, cap, rotor and coil and some cooling system parts.
Took it to the ramp and lowered it in water and water starts coming in through the bellows. I decided to start it up and let it warm up to around 120, I lowered the drive and started giving it gas sounded good but some vibration. I thinking u-joint. Anyway it will go to around 2500-3000 rpm the drop to zero and sputter and sometimes die. Then start back up. I was running 87 octane and I think my arrester may be a little dirty. I cleaned the arrester, confirmed plug where wired correctly, and I guess I add some octane boost. I checked the compression when it was cold, I now know those numbers aren't any good. Going to warm engine and check again.
Any comment on the above or these plugs? the two to the left are #1 and 4
http://i212.photobucket.com/albums/cc84/vman858/2002 180se Chaparral/20130330_192404_zps00096477.jpg
http://i212.photobucket.com/albums/cc84/vman858/2002 180se Chaparral/20130330_192350_zps6e9b84c7.jpg
