charliedaubitz
- Sep 1, 2008
- 34
I bought a 1977 Webbcraft with a stringer I/O and a 351w. it has a ss prop on it and on the first trip to test it, it went forward, with the control in reverse, this is a electric shift pin drive, no splines prop. I have the work history on the boat and the I/O was removed 7 years ago and I don't think the boat has been to the lake since.
I just switched wires to the magnets and that fixed the problem. If someone put the wrong rotation prop on the boat, is there any difference in the gears for forward or reverse. thrust washers or whatever. What direction rotation is correct. it's a 981105 lower unit with a 172491 michigan prop that needs a new hub.
I marked it and it's slipping. Could I press the old hub out and use crazyglue on it and press it back in after cleaning. I took it to a prop shop and they can't get the correct durometer rubber hub for a ss prop because of it's age. in the meantime I bought a 14x16 off ebay. the prop shop has the hub for a aluminum prop if it needs it.
