1999 90 H.P.
Serial # 0e 355074
Model # H090412VT
Trying to figure out how to disengage "shifter rod" to drop lower unit to replace impeller. I cant find anything on this. I've seen them with the nuts (Mid section)that come apart as well as the pin that can be removed up top. Cant find either on mine. Is it possible that I can just drop it without disconnecting "shift rod/unsure of part name"? Thanks in advance for any help.
Serial # 0e 355074
Model # H090412VT
