little.boat
- Mar 25, 2013
- 73
I have no idea where this goes. I'm am new to boating never owned a outboard. I got a 1999 force outboard 90hp motor on my 15' bass boat it is rated for 90hp max. Motor seems to run fine compression is perfect along all cylinders. We put it in today when we get much over idle barely going it feels like it is slipping out of gear. Won't push boat to raise bow at all. So I hit the forum I kept reading about a slipped prop. Took it to the mechanic and he said prop is not slipped and is good. We put it in gear turned it backwards and it turns the motor over. He also said it doesn't seem like the lower unit is bad. He said prop is probably to big, it was a 19 pitch, he said 17 should work. Does this sound right? Also we had prop trimmed all the way down at take off. Should the prop be trimmed all the way down or should it be trimmed up and adjusted down to plane it? Just seems like that motor should push that boat faster than barely moving lol. Sorry guys but it is a old boat so no gauges.
