Radarman68
- Oct 27, 2012
- 28
Folks, I think I have the correct parts, but before I pull the trigger can I get you folks to help confirm I am looking at the right parts?
I have a 1981 Century Arabian with a Mercruiser 260:
Lower unit SN 5622736
Transom SN 5708753
Engine SN 5834135
if I am reading the matierial here on the site, it looks like I have a 1980 model MC-1, with a 1.5 gear ratio..
The boat has not been in the water in about 3 years, so I am changing the engine oil and outdrive oils, that stuff I have found references as to what to use already, however...
My questions are:
1) what trim motor fluid should I be using?
2) what water pump part number should I use? It looks like I need "#1 Units (Except MR-ALPHA) w/o flush screw in gear housing, PN 18-3317(1)" is this correct?
3) and last, which transom seal kit should I go with? Part # 18-2601-1 ?
thanks in advance everyone, I have really been learning a lot from reading all the great information on this site.
Transom SN 5708753
Engine SN 5834135
My questions are:
