There must be twenty different types of "bearing buddy" type products on the market from the original to aftermarket no-name versions now. But since they all seem to work pretty much the same way, I can't see much difference in one being better then the next. Personally I?ll buy the stainless steel type myself instead of some plated steel. But that is just my opinion and I'm sure others have actual experience with different types and can explain the better ones... The one issue I know too many folks do is fill them too full with grease. Some think putting a stroke of grease into them every time they take the boat out is the way to go. But that leads to the rear seal failing because the grease has to go somewhere. So the proper way to fill them (after you grease the bearings initially before placing them on the spindle like usual) is pump grease into them only until you see the internal piston/disk just starting to move outward. Anymore will overfill them and exert more pressure on the rear grease seal. And once that piston/disk gets to the end of its travel, the grease will rupture the rear seal...hydraulic pressure! JMHO!
The newest version have a small relief hole that will ooze a little grease before you pump enough to blow the seal. At least, that's the plan.
I had Bearing Buddies installed on my previous boat's trailer (ShoreLand'r) and I thought that was great technology at that time. I always made sure to grease them exactly as the members on this thread explain the proper way is to do so. I never had a bearing problem in the 13 years of that trailer's existence.
Then I bought my new boat with a new trailer to go with it. I asked about getting Bearing Buddies installed and I was advised that they (Load-Rite) didn't use them anymore. They use a system from Tie Down Engineering called Sup-R-Lube. They make two styles, hubs or spindles. The technology completely replaces the old grease in both the inner and outer bearings as you pump in new grease from your grease gun; it also doesn't put pressure on the rear seal doing so. I've only had the trailer for two years, but I have to say, I think the technology is pretty cool. It doesn't negate good, annual bearing maintenance practices, but I like the way it completely changes the old grease with new (and hopefully pushes out anything else that shouldn't be in there).
Here's a link to the owners manual on Tie Down's website if you're interested:
http://www.tiedown.com/pdf/c718.pdf
Got a link for those oil filled hubs?
