Hi guys, im fairly new to the boating scene (and forums) and i appologise if this is a silly question, but;
I have just picked up a blueband mercury 6s (650 thunderbolt) which has not been run for 12 months.
I rewired it all and checked over everything (fixed some minor issues) cranked it over (had to belt the starter several times lol) and she turned over and over, then fired and basically runs very well, but is not pumping water (atleast not coming from the pee hole)
So ive proceeded to remove the lower unit to check out the impellor and for the life of me it just will not come out. Ive loosened all the bolts as per a diagram ive found it has slightly come apart but now seems to be stuck.
I have a feeling it could be the gear shifter rod but i cannot find anywhere to disconnect it from? Keen to get the boat on the water tommorrow so any help would be much appreciated ;-)
