long struggle with this one...engine will always start, and generally idles well once warmed up a little with just an occasional 'sneeze'. Runs fine in gear at slow speed, and about 30 knots or anywhere in between on the back of our 17' Whaler. But...if you've just done a prolonged slow speed run, and then drop to neutral, it will often stall. She immediately re-starts without any extra throttle, and off you go. It seems like it will have fits of the stalling thing, and then run fine for a while. I have cleaned up the carbs a couple times, got the correct spark plugs in her, rebuilt the fuel pump, new filter/water separator cartridge, experimented with fuel supply lines and tanks, and started running a tank with SeaFoam in it. Any ideas on where to go next would be appreciated.
