whichyadidya
- Mar 27, 2013
- 3
Hello all. I am new to this forum. I just bought a 14 ft. old, aluminum v-hull boat with a 9.9 johnson tiller motor on it. The motor runs great aside from a loose tiller handle which I fixed. Anyways...this is my first boat and I know basically nothing at all about it. I just know I want to catch snook, trout, redfish and snapper whenever the mood may strike me...that being said I have been looking around the forums here and I have yet to see someone put a flat deck on the entire top of an aluminum boat. I was thinking about using some balsa wood support blocks underneath some really really thin plywood. On top of that a couple layers of fiberglass. Then epoxy that right to the top of the boat. Basically just a deck. Obviously it would have all the little compartments built into it and stuff. But. Is this a bad idea or? I can't really think of a better way to explain it. I would stop the deck right in front of where I would normally be sitting to control the motor...so from that first bench up it would be all flat. Like a really expensive fiberglass flats boat. Is there any reason this wouldn't work?
