Hello guyzs,
wondering if someone could think of something I haven't?
I have a 1986 Mercruiser 4.3LX with an Alpha One Gen 1 leg, fitted with 3in risers. 4BL Rochester, Thunderbolt IV ignition.
The issue the motor has is:
- numbers 5 and 6 are sooting up at low RPM
- numbers 1,2,3 and 4 are absolutely perfect.
- runs fine at higer RPM
I have changed the following:
- fitted 3 set of plugs
- changed plugs 1-4 into 5 and 6 (known good plugs)
- new set of leads
- changes leads from 1-4 into 5 and 6 (known good leads)
- new distrubutor cap
- new rotor
- different carby
I think I've exhausted ignition issue problems
I don't think its a carburettor issue as 4 out of 6 plugs are perfect and runs well at 2000rpm and above
I don't think its an air leak issue because the plugs would run lean and again the boat runs well at high rpm
I haven't checked the valve clearances. The engines has done around 10 hours work and the lifters have not been checked since. Now that the hydraulic lifters may have fully pump up and closed the valve clearances on 5 and 6?
I plan over Easter to do a leak down test...
Does anyone have any other ideas I can check out whilst doing this?
cheers
Dave
- new set of leads
- new rotor
- different carby
cheers
Dave
