Re: 2 MPG evinrude lark V 40 HP
"Looked good". Well maybe yes, maybe not. Did you do the disconnected hose like I suggested?
As far as internal engine damage, have you checked the compression? That should have been your very first step. Sorry we didn't suggest it.
Second step should have been an ignition inspection. It could be running on one cylinder. (The non firing plug would be wet). Sorry we didn't suggest that too.
Everybody jumps to conclusion and assumes it is a fuel problem. Including me this time. Sorry again.
Hey, it could be your lucky day and it may be as simple as a bad spark plug.
Oops, you said it is going 18-23 MPH. It probably wouldn't go that fast on one cylinder. That is what is confusing us. A little clarification here. Was performance "normal"? 18-23 is kind of slow for two cylinders. Back to compression.
