Hi, I was hoping someone might tell me whats going on. I have a 1964 28 hp evenrude I bought it used from someone and gave it a test run. Started then started missing, I guess there is another terminology for when it does that. Anyway I had to replace the head, replaced head and adjusted the points to .020 put it back together and test ran it again, Now there is no spark in the upper cylinder and good spark on the lower. Any ideas? Will the cut-out cause the upper to not fire? When my friend toughed the lower motor frame he said he got a shock. What does that mean?
thanks
thanks
