fartztheboater
- Mar 22, 2013
- 7
Trying to get my 40 to idle and run smooth!!!
In a nutshell, I purchased the 40 not knowing anything about how the engine operates, always used early outboards 24/1 ratio engines. anyway when I purchased the engine they ran it and it ran ok on the hose I was in a hurry so I gave them the money and put the engine in my hatchback, 5 months later (now) and 1000 miles away (new location) I have the engine on my boat it runs the same but the red lever on the side is not in the auto position they told me at time of purchase that the red lever adjusts the mixture (wrong they were). If I put the lever in the auto position I have to keep pushing in on the key to keep it running and it runs very rich! I have went through the carbs twice and there is nothing in the carbs initially there was but they are clean, clean ! I have set the floats to level when the carbs are upside down. I cleaned the needle and seat with extra fine steelwool and have checked the needle and seat when the carbs were put back together with air pressure and they work smoothly seating and unseating. the vro is plugged on the oil side and does not leak any air in, I have replaced the fuel filter with an aftermarket clear one and use 50:1 premix! the primer appears to be operating normal, clicks when key pressed in! the thermostat leaks a little past the seal when I blow through it, and it does open all the way when I put it in preboiling water? I dont think the thermostat is the culprit. If the engine runs when I baby the key pushing it in doesnt my prob have to be the carbs??? the only link and synk info I can find online is setting up the cam roller and throttle opening sequence. I think the current sync is ok?? the compression is 137 on each cyc! the plugs are new but fouled, I dont think the plugs are the issue either.
When I bump the key, push in and get it to run (rich) I can push the fast idle lever up and the engine will increase and run up, but is soon loads up with fuel and stalls?????
I have been cussing this thing and I feel defeated please help!!!!
I have repaired and rebuilt other outboards and jetskis and feel I know a little about two stroke engines except this one????
Help!!!!!!
Help!!!!!!
