I just bought a 15 hp gamefisher (force) for a $100. I put a new water pump on it,cleaned the carb and replaced fuel lines. Compression is 90 on ea. cyd. I'm having a fuel issue and not sure what else I can do. It is loading up on #2 cyd. Once I dry it out, it's hard to start. The primer bulb is broke and not sure if that is the part of the problem. Any help is greatly appreciated. also it is a 1990 model.
