  #1
Old January 31st, 2005, 10:37 AM
Parrot6909 Parrot6909 is offline
Default How do I patch holes in center console?
I purchased a 16' Garvey with a v-hull about a month or so ago. It needs a ton of work, new floor, paint, steering and possibly the motor. With all of these costly items in store for me and not a huge budget, I wanted to know if anyone has suggestions for cleaning up the console itself. It has holes from prior drillings for a compass, depth finder, vhf etc. Some are 2" or more wide while others are a normal size screw hole. I'd like to have a "like new" boat look when I am done. Any suggestions would be great. Tried searching a bunch of different ways before posting but couldn't find what I needed. Thanks in advance!
  #2
Old January 31st, 2005, 12:58 PM
Buttanic Buttanic is offline
Default Re: How do I patch holes in center console?
I just completed a similar job. Run a drill bit a size larger than the screw holes through them to clean them out . Then use a counter sink and lightly counter sink the outside of the holes.I used a epoxy putty stick from Home Depot, pushed it into the holes but left it a little high on the outside so it could be sanded flush. For the larger holes I cleaned the edges with sandpaper and bonded a piece of glass cloth over the inside of the hole. I then cut peices of mat and cloth to the size of the hole and laminated them in. Leave the lamination a little below the surface and use filler to fair it in. I used epoxy resin to laminate and added cabosil to it to fair the hole. This is not a structural repair and this is strong enough.
  #3
Old January 31st, 2005, 02:34 PM
JasonJ's Avatar
JasonJ JasonJ is offline
If the holes are fairly close, you could always mount all your guages and switches on a piece of aluminum that is large enough to cover the area those holes are in. If they are spread all over the console, Buttanics technique is the better bet...
__________________
Project Skanky Beast http://70silverline.250free.com/Skankybeast.html
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
Center Console Scott-14 Boat Topics and Questions (not engine topics) 6 October 15th, 2003 03:18 PM
Center Console Scott-14 Freshwater Fishing 1 September 30th, 2003 03:48 PM
Filling holes in center console stretch Boat Topics and Questions (not engine topics) 6 August 27th, 2002 05:50 PM
19'-21' center console gatorperk Boat Topics and Questions (not engine topics) 6 February 15th, 2002 01:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
