I have a 1990 40 hp evinrude that stalls only when in the water at full throttle. Runs great in nuetral in the water or hooked to a hose. I have put in new tank , new gas lines , rebuilt both carbs, new fuel pump, new plugs and wires, tried a coil off of another boat that i know works. new water pump , new thermostate tried another heat sensor just to see if it was shorting out. Ive tried a smaller prop to see if that was bogging it down. I tried disconnecting the choke. Unhooked the throttle linkage and tried to run with just the carb . Nothing seems to make a difference.. PLEASE HELP
