Hi..
I have removed the drive for a water pump change and also been told that my seal carrier was not in great shape so I decided to replace this...
When I removed this the drive shaft had some play exactly like in the below video.
Mercruiser Alpha One Gen II Bearing problems - YouTube
What is the way forward?
Can I change this with the lower part gears and shaft still in place?
If I remove the ?nut? will I have access to the bearing and change it with the shaft still in place?
Thx
Thx
