I have an 89 OMC 2.3L in my boat. I am getting ready to pull the distributor out and replace the springs. I have a dead spot on initial acceleration and I am going to replace the points with a pointless ignition and flame thrower coil with a resistor. I have rebuilt the carb and it did nothing but run smoother but did not fix hole shot. I am going to purchase a re manufactured carb. The boat runs awesome just; except that one small problem. I know that the timing at an idle is 10 degree BTDC but I do not know how fast the timing should advance and how far it should advance. What is the Max timing advance? I have looked in the book but am unable to find it. How fast should the timing advance from Idle to 1800rpm?
