Re: What kind of hull design would you call this?
they all do that... the rounded back doesn't change anything... it is just a V hull
I have two wellcrafts... one is a 28' cruiser and it has a sharper dead rise angle at the front than the rear The other is a 20' center console fisherman boat and it has a much sharper angle at the front with wide bow flairs and the same rounded portion at the rear but neither of them gets any special name other than "V" or "Deep V"
Don't let it bother you, your hull doesn't need a special name to bring you a lot of enjoyment on the water and if you really want a name then make up a witty one and paint it on the transom
