usedcarman
- Feb 13, 2010
- 29
Hi Folks,
I just picked a used 1999 Lund Angler 1700, that weighs about 960lbs dry weight, and it has a 1999 Suzuki DF70 four stroke that weighs about 319lbs. Problem is there was no prop on the engine when i bought the unit, it had been damaged, engine runs fine nonetheless. But now i can't seem to find where to look for the proper prop to install on this boat. I'm a walleye fisherman, i troll a lot and speed is also somewhat on a concern to get from hole to hole, as is holeshot. I usually like to troll at speeds between 1 and 2.5 mph. Could anyone suggest a proper pitch for this unit, or direct me to a site where it can be calculated?
Thank you!
Thank you!
