Dorkynhymer
- Mar 16, 2013
- 5
i have a 1969 -16' Alpex by Alumacraft fiberglass tri-hull with a 1969 Johnson 33hp . after reading in the iboat forum i discovered that boat and motor are mis-matched maybe . i have a 20" transom and the cavitation plate on the motor is 3" below the bottom of the boat . i measured from the cavitation plate to the mount bracket as 23" . i thought the shaft sizes were 15-20-25. i do notice at full throttle the boat doesnt fully plane the bow rides high and plows the water .does this make sense and what should i do. this is my first thread and would appreciate any input thanks
