DAMIEMARIAH
- Feb 3, 2013
- 25
Hi All,
I have a 2006 Mercruiser 5.7tks engine that i have converted to my Volvo drive, i have fitted back my Volvo manifolds and risers but the thermostat housing has 4 hoses that originaly went to the mercruiser risers, and 1 larger on the left that goes my circulation pump and opposite ( on the right) i assume this last one must be the water supply from the raw water pump, my Volvo manifolds only have 2 hoses. Do i use the 2 on the top of the housing that look like a T piece screwed into the top of it and blank off the other 2 that are above the thermostat chamber?
Many Thanks.
I know its an odd question but if you read my previous posts you this will explain my reasons for the mix and match!
Many Thanks
Damian.
Many Thanks.
Many Thanks
Damian.
