Re: 60 evinrude underway but no plane.
Thanks guys. I have a tach and it idles around 1500+-. Ill I've it a comp test when I get home thanks..
I believe that is WAY too high for that motor to idle. It should be closer to 700-900 RPMs in gear. Maybe 1000 on muffs with no backpressure from the exhaust. Check your specs.
I also changes out the throttle cable a few months ago. Seems te carbs open up to full throttle but the motor just won't plane... Rpms show it as they are in the 2.5-3k range with throttle maxed
WOT RPM range ( Which you are testing in the water under load, right?) should be 5500 RPM if memory serves. You are not getting full capabilities on that motor. Either you are not running a cylinder (at 3K RPM that would be my initial uninformed guess) or the motor is way over-propped and lugging.
Verify compression, spark. Also,verify that you are running all cylinders with a cylinder drop test (With engine running, pull one plug. If there is no change, then that cylinder is not running. If the motor starts to run erratically or cuts out, then that cylinder is running. Try the same with the next plug. )
If all your cylinders are running, then you have to look at the motor being over-propped, your boat is not matched with your motor, or you might possibly have saturated foam which is causing your boat to be inordinately heavy.
Good luck.
