cecho
- Jan 29, 2013
- 367
You mean the bearing not level with the outer housing ??? It does that . . .
When you install the bearing and insert your alignment tool, you will actually use the tool to pivot the bearing within the carrier a few degrees to get it pointed in the correct direction to meet the coupler. From there, it is a matter of aligning the engine so the drive shaft goes in smoothly without binding, etc.
The metal shield were link belt is stamped is deformed a little. This shouldnt be a problem. the actual seal is under the cover(i think).
