Howdy,
I got a new boat about a year ago with a 2003 Mercury 150. I cranked the engine up for the first time this year, and it was not pumping water (it was on the trailer with the "ear muffs" on). So, I figured it was the impeller. Being a newbie boat owner, I found all of the articles and references very helpful.
I didn't have too many issues, however when I tried to put the lower unit back on, the shift shaft was not lining up. I've come to the conclusion that I did not put it into forward enough and I must've moved the lower unit shift spline while I was working on the impeller. Sooo, I put the control back into Neutral, and I grabbed some pliers and I am pretty sure I got the lower unit in Neutral. I did this by turning the drive shaft CW and watch the prop turn as I rotated the shift spline CCW. The prop would stop turning. As I continued to turn the drive shaft, the prop would go from stopped to reversed rotation. So, I put it back to where it was stopped when I would rotate the drive shaft.
I made sure the control was back in Neutral, and slid the lower unit back on. I had to rotate the drive shaft a bit, but it fit back on and I bolted it up. In Neutral, my prop free spins. In Forward, it is locked, and in Reverse it is locked.
My reason for this post is:
1) Did I go about getting the lower unit back in the proper gear correctly? Should I be concerned about firing up the engine? It seems like it shifts into gear a bit "tougher" (engine not running) than it was, but that could be my faulty memory.
2) I found a lot of misc comments about recovering from this, but it was all spread out. On the chance that I did it correctly, I figured it would be helpful. On the chance that I did it incorrectly ... hopefully I'll get some feedback.
Thanks in advance! -Jerod
