Crappie Reaper
- Mar 14, 2013
- 13
'93 Johnson, 115 hp V4
Previous owner removed the oil tank, unpluged the electrical for the oiler and has been premixing the fuel. I've just rebuilt both carbs and was still having trouble with the motor under the cups. It was acting like it had too much air mixing with the fuel so I was going back over the hose fitings. I noticed the fuel inlet hose into the pump was not up all the way, moved the clamp down and while trying to move the hose up tighter, part of the pump broke and exposed a couple of ports surrounded by sealed with O rings. Marine parts house informs me that I need a new pump as it's not repairable.
I'm looking into replacing the VRO pump with a regular pump. I've no idea what part number to purchase. The Dealers parts man told me I would need a diaphram as well. I've read many of the older threads concerning this issue, but most involved Loopers.
Questions
1- What model number fuel pump will work?
2- I've got the fuel line from primer bulb feeding in, plus two other lines that were connected to the pump. Do the other two lines feed each of the two carbs? Note* the oiler line was already disconnected.
3- Will I need to purchase a diaphram?
I could use some step by step guidance on this and do appreciate any help.
Questions
