Hi all,
First trip out this spring last weekend, and the tilt was clearly struggling: moving very slowly, particularly when tilting down. It ground almost to a halt several times, but never quite died. At the very end of the trip, it did quit moving completely, and melted the insulation off of the wiring that runs from the trim/tilt motor up under the cowl, and one 6" length of wire under the cowl. I'm guessing that the problem is the trim/tilt motor itself, but wanted to hear from folks who know more than I do (that's most of you!). Does this sound like a problem with the trim/tilt motor, as opposed to a relay or the ram? Are there any ways to diagnose for sure? And finally, assuming it is the motor, is it best to just replace the motor/reservoir unit with an aftermarket unit rather than trying to rebuild?
Thanks,
Lewis
Thanks,
Lewis
