Re: magnetic drain plug
Having a magnetic plug on the fill and vent plugs is sort of like having a belt and suspenders. More than you need but no chance you are going to drop your pants. I'm a belt and suspenders kind of guy. For the small extra cost why not? Also if you only have the drain and vent gaskets on for an hour you should be fine, but again for the small extra cost why take the chance? They do get mashed flat once you use them. I remember when you bought that boat. How is everything else going with it?
