My 1997 Johnson only starts with ether
Bstrake
The motor is a 3.3 and has been sitting for about a yearThe carburetor was redone last year and if I unscrew the bolt gas flows out. I put fresh mix gas in it and still nothing but as soon as I spray ether in the carb it fires and then dies. Any help would be great thank you
rrw
Re: My 1997 Johnson only starts with ether
Hi there, either is not good for 2 strokes, it doesn't contain any oil, and actually washes the oil that is in the crank case out, especially if your not sucking any gas(oil) into engine this is bad. I use a small spray bottle with mixed 2 stroke gas, just don't spray while engine is running or even turning over. I would start by pulling the spark plug and checking if your getting gas into cylinder. Your carb jets could be gunked up. You apparently have spark and compression, and sounds like your getting gas into carb, probably not from carb into engine though. Just my opinion on where I would start. Hope this helps. Ryan
hsdtech
Definitely a fuel issue. Pull the carb and go through it and clean it real good with carb cleaner.
boobie
What's the compression and spark like on it ??
Chris1956
If you need to use ether, you have a weak spark, no choke or a possible flooding condition.
Chris1956
Sorry, I forgot one possible issue. You may have low compression. Time for a compression test, spark test and then post back.
boobie
Chris, read post # 4.
Chris1956
boobie, is it a bad thing to reinforce a good idea?
boobie
No..............
