I have a pair of 1996 Johnson Ocean Runners and one outboard would start and idle without issue the other would start and not idle well and shut off. They both would run well once in gear and with the rpms up. Now my issue is I changed the fuel filters and the port engine would start and idle like it did before but the starboard would not start so I checked the fire at the coils and two of the six coils were not firing. I took two coils off the port engine and put them on the starboard engine in place of the two that were not firing and they still didn't seem to fire. When I put them back on the port engine it now will not start and some of the coils have fire sometimes and other times they have nothing. I am a bit confused as to what happened or what could be wrong. Could it be the kill switch working intermittently because every now and then they will both fire off and then shut off again.
Any help you can give me would make it easier on me to troubleshoot.
Thanks,
Matt
Thanks,
Matt
