Hey guys,
I have a 1968/69 Johnson 25 hp tiller control outboard that I need to install a push start button and maybe a kill button. The motor was on a center console boat but now on a much smaller boat and I don't need an ignition switch. The motor has the wiring harness (ABOUT 6 FEET LONG) coming out of the motor but I am not sure if the color wires are correct.The motor does not have a choke solenoid so I don't have to worry about that. What wires do I attach to the start button? I presume I can still use the battery wires in the wiring harness (heavy guage black and red wires with battery connectors on the ends) to attach to the battery.. Also how would I wire a kill switch as I don't want to use the pull out choke to kill the motor?
All help would be appreciated
Thanks in advance.
Respectfully
Brian
Thanks in advance.
Respectfully
Brian
