Hi Guys
FWD will not engage on the outboard.
Its not the cable the lever shifts fully forward and back and you can see parts mving in the outboard with the lid off.
It will shift between reverse and neutral fine no problems
While playing with it yesterday at home with the earmuffs on. I think I may have gotten it too engage if I move it from reverse to neutral to fwd, if I continue to do this gently it seems to engage 1 out of 5 times.
Would this be the cluch dog? How easy would it be to check this for an absolute amateur...
Can I easily drop the leg and have a look or will I need specialist tools?
Thanks
Thanks
