Re: Top carb too much gas? 92 e60tle
First off, what is the compession on each cylinder? That's the first thing to check to make sure the powerhead is worth putting $ and repair effort into it. Assuming it's ok, you've either got a fuel or spark issue if it won't plane out. Probably easiest is to check for spark. (it either sparks on all 3 cyls or not.) You can easily check for spark with an inductive timing light. Attached to the spark plug wire, the flashes from the gun will show the quality of spark misfires, no firing, etc-while the engine is running on the trailer. I'd make sure the engine is fully warmed up prior to doing the test. (Weak ignition components tend to fail once the engine comes up to normal operating temps.) That engine may seem to run fine on the trailer in the back yard, while only running on 2 cyls. You need all 3 firing when in the lake. You mentioned you've confirmed the spark is ok. I'd visually check to make sure the timer base is advancing properly when the spark advance lever is moving to WOT. If it all checks out-now you are on to the next phase-looking at the fuel delivery system.
