Re: 1957 Evinrude 18 hp Fastwin Electric 18 carburetor rebuild
Well I guess it depends on your budget, how often you would use it, etc... The coils can be set by ensuring the laminations are flush with the mounting boss using your fingernail. Run it up mounting boss, if it catches on the laminations, too far out.
That being said, I have all of Franks tools and love them all. You cannot buy better, I highly reccomend all of them. The timing fixture is the one I use the most. If you work on alot of pressure tanks, the tool for removing the o rings is a must have as well.
