How do you convert to using a fuel pump instead of a pressurized tank?I did this once years ago on a 15hp but can't recall exactly what I did .Thanks for any help .
Simple on that motor. One of the bypass covers should have three holes in a row. Drill the center one through, and tap threads #10-24 in the other two. Then attach a standard Evinrude (Sierra here at iboats) and connect the hoses. You also will need a single line fuel connector to replace the current twin hose one. Plug the current air hose.
EDIT: Picture is in error. Threads are to be 10-24, not 10-32
