dthomas1015
- Mar 10, 2013
- 11
E70elcte
K well,
This is what happens.
I'll run around low throttle for about an hour everything's fine.
10 min of running full throttle and it cuts down to very little power instantly
Just enough to make it back in. I will say that it did seem to run rather rough
The motor doesn't feel hot though
Lots of water flow
I get home an hr later and it starts instantly and will rev up instantly
I think it's the temperature sensor.
My friend was once an outboard merc mechanic and pointed me in this direction
I got in late today and plan to ground out the temp sensor wiring to listen for a warning siren
Though I'm not entirely sure that there is one on my throttle
What I'm really interested in is "slow mode" I've been reading lots of threads and this is a common issue
Would a faulty temp sensor put my outboard in slow mode?
Impeller was done, leg was serviced, carbs were cleaned, new spark plugs. Fuel system does not seem to be the issue. Runs fine until I run her full blast for ten minutes
Any ideas would be greatly appreciated.
K well,
Lots of water flow
