mattsmall1972
- May 14, 2006
- 238
I've got a 1982 Evinrude 35 hp, remote start and steering. I've never had any problems until yesterday, my first time out this year. Attached a charged battery the other night, ready to go fishing the next morning. In the morning, the engine would not turn over - it tried but the battery didn't have the juice. Swapped the cables to the trolling motor battery and tried again. It then turned over great but wouldn't catch.
At first I though it was a gas problem - the tank had some in it from the previous season. I got another tank with all new fresh gas and oil, but it did not help.
After getting it home, I checked the plugs. They appear to be in good shape, but I cannot see any spark when cranking over. I attached a jumper cable from the negative to the plug ground but still nothing from either plug wire. I assume this is my issue.
I've searched the forums and see that I need to figure out what's bad: powerpack (cdi I think?), coils or stator. I already tried disconnecting the black/yellow wire from the powerpack and it did not help, and neither did jumping the kill switch.
I have no experience with troubleshooting this. I will get a dvi, but I don't understand what to do or measure. Can you help me out?
Thanks.
Thanks.
