Zee-L- Usay
- Mar 10, 2013
- 1
I bought a place and the old owner did a lot of boat repairs. I have found all sorts of stuff(that would be spelled with an "sh":joyous stuck in many corners of ... well everywhere on the property. I can I.D. most of the things I found but these little cans.
I finally, after 1 1/2 years started to move an old firewood bin. But to my surprise it was a cabinet and was full of sh... stuff. There were about a dozen throttle/gear cables all but two were garbage. Some control levers and lots of pieces of wire, seat foam, etc. But then I found a plastic bag with 13 "tin" cans in it.
These cans are silver, 3.5 inches round, 3 inches tall, (about the size of a mothers metal polish can) plain with only a small business card sized white with black lettering label. It reads:
RACHWEL L-6
Part#9098105
70mm X 42m
XSM2 E.I. P.
21341610 0
2ZLNN
Made in Germany
Inside the can is the same plain metal as the outside but there are thin white parallel lines on the bottom, about 1/8" thick, 1" apart. the sides have 3 of the same line forming rings.
My question is "what's the bus drivers name?"; No wait it's "what came in the cans?" I think some sort of tape but it was thin for 42 meters to fit into these cans.
Thanks for any info.
Zee
RACHWEL L-6
Part#9098105
70mm X 42m
XSM2 E.I. P.
21341610 0
2ZLNN
Made in Germany
Zee
