Re: Gas/Oil Mixture
Welcome to iboats Petey.
Yes.
Any modern tcw3 oil will readily mix throughout the gas in a few minutes.
It is one of the requirements of being tcw3 rated.
Some people will tell you to premix in a separate can, but it really is not necessary.
Put it in first or last, but get the correct amount of oil.
Easy to figure out no matter how much gas is involved, 2.6 ounces of oil per gallon of gas.
But not knowing how much gas you may put in, perhaps the safest method is to put in half of the anticipated oil, add the gas, then calculate and top off with oil to bring you to the 50:1 ratio.
It would really suck to fill the tank with gas, and not have enough room to add the required amount of oil.
